kwalampur's avatar
kwalampur
Follower
Feb 07, 2023
Netgear Nighthawk R7000 Question
Hello all,
I was hoping for some insight regarding some recent issues with my router and if it is router issue or my abysmal WiFi.
Long story short, I have the Nighthawk R7000 and am experienced sporadic network disconnecting. I have to reset the router around 3-5 times a week for WiFi dropping for no apparent reason. Additionally, I experience significant networking issues playing most video games (of note, Warzone).
I have all home devices on the 2.4 GHz network, with maybe 1 or 2 devices on the 5 GHz network and plug my Xbox directly into the router. I have microwave internet and my WiFi download speed is around 10 Mbps download, and .70 upload (abysmal I know; I live in the country)
From reading through other posts, it appears that upgrading the firmware resolves that issue. However, I currently have the stock .88 firmware, with no upgrades available on the app.
Im considering trying a new router and then switching to literally any other internet providers (only other options here are satellite) but wanted to receive any input from y’all before I do so.
Thank you for taking the time to help.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    How do you have the Basic and Advanced Wireless settings configured?
    Is Smart Connect enabled?
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Be sure to enable WMM, Beamforming and MIMO.
    Armor, Smart Parental Controls or Circle, Traffic Meter.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    FYI:
    https://community.netgear.com/t5/Nighthawk-Wi-Fi-5-AC-Routers/New-R7000-Firmware-Version-1-0-11-136-Released/td-p/2245573/jump-to/first-unread-message
  • plemans's avatar
    The .88 was a fairly solid firmware and has likely been on your router for ages.
    And your issues happens with hardwired devices as well.
    I'd be more suspicious of your broadcast internet being the issue as random things can cause interference with it at those low of levels.
    What happens if you hardwire the xbox directly to the broadcast internet connection and run it?
    Do you still get drops (run it for long enough to ensure stabily or lack of)
