BuckGuy
Nov 24, 2020Tutor
Netgear Nighthawk R7960P Not Allowing Full ISP Speed
I recently increased my Internet speed through my ISP to 500 down / 50 up, but my Netgear Nighthawk is throttling my download speeds. I'm maxing out at about 300 Mbps down. Upload speed is fine. Plugging directly into my cable modem, I am getting 490+/50+. I do not have QOS or Traffic Metering enabled. The speed test directly through the Netgear router under QOS is also recognizing the speed, showing 500+/50+. I am currently on firmware version V1.4.1.50_1.3.10. Any help/ideas would be greatly appreciated. Thought about aggregating a couple of the ethernet ports to see if that would help, but these are gigabit ports, so that shouldn't be required. Also, this is all hardwired.
Did you ever try a factory reset and clean reinstall? (not from backup)
Try that first. During the install, make sure to leave qos, traffic monitoring, parental controls, and access controls disabled.
- BuckGuyTutor
I'll try that, thanks. Appreciate the reply.
- BuckGuyTutor
OK, I performed a factory reset and have not reconfigured anything other than the device password. I have not yet configured wifi, and QOS, traffic metering, parental controls, and access control all disabled, but I am still running into the same issue. Speedtest through the device shows 500+ down, but the most I can get through my hardwired PC is 350+. Wiring my PC directly into the modem gets me 490+.
That gets you part of the way there.
You need to reset the whole network, including the modem.
Then start everything up afresh.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
Everything on your network has to forget any settings that it had when you had slower internet.
BuckGuy wrote:
I have not yet configured wifi, and QOS, traffic metering, parental controls, and access control all disabled...
At 500 Mbps, QoS is pointless and will only slow things down.
I just got xfinity to install a gig speed modem this weekend. It's connected via an ether net cable to my R7000 Nighthawk router. The installation tech verified that 980 mbps is being received at the router but when I test the speed of the router on speedtest, the router is only generating 200 to 400 mbps even if I'm standing right next to it. Does anybody know why I wouldn't be getting the full gig of speed? Thanks
The R7000 is not the same as the R7960P discussed in this conversation.
elanaalex wrote:
...the router is only generating 200 to 400 mbps even if I'm standing right next to it.
Wifi?
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.You could also explain which of the various suggestions put forward in this conversation that you have tried.
> conversation.Your detailed reply to a scam-link post might be wasted effort.
https://community.netgear.com/t5/x/x/td-p/1514609
Look familiar?
