21kidsanddogs's avatar
Jun 05, 2025
Netgear R7000
i was getting buffering - checked the modum and that was good- unplugged the router - finally reset it -  but when i try to connect the router to my computer with the ethenet cord
the routerlogin - the page never loads
not sure where to go from here - purchased in 2021 so its not that old and its been a great router with a good range to reach my back field where i monitor bluebirds with a blink camera
  • yes i reset the router - i tired using an ethernet cord to go to the login page and tried 192.168.1.1
    the page would never load
    • FURRYe38's avatar
      Even a factory reset and setup from scratch with the router not connected to the ISP modem/ONT? Could not access at 192.168.1.1?
  • FURRYe38's avatar
    Does connecting to 192.168.1.1  work?
    What FW version is loaded?
    How did you reset the router? Press the back button for 15 seconds then release?
