NguyenDo's avatar
NguyenDo
Netgear R7300DST can not use IPTV
Hi guys,
I have a Netgear R7300 come with DST. However, I can not use IPTV, I also do the guide how to use IPTV on Netgear website but it couldn't work. Could you please help me to set up R7300 to use IPTV from ISP.
Thanks all.
  • That's correct.
    The model is intended to be used in the US and exclusively bought at BestBuy.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hello NguyenDo
    Welcome to the community!
    Try to see if enabling IGMP will help.
    The setting can be found by accessing the admin page then under WAN Setup.
    • NguyenDo's avatar
      NguyenDo
      Hi ElaineM,
      Thanks for your reply. I also had tried to enable IGMP but it didn't work. Do you have any solutions?
      • ElaineM's avatar
        ElaineM
        Do you get any error message?
        Who's the provider for your IPTV?
        How is the IPTV configured, wired or wireless?
        Just to verify, you also have followed the step-by-step instructions from this site, right?
