paillassou
Mar 31, 2021Apprentice
NETGEAR R7800 FIRMWARE v1.0.2.82
NETGEAR R7800 FIRMWARE v1.0.2.82 issues
https://www.downloads.netgear.com/files/GDC/R7800/R7800-V1.0.2.82.zip
BE CAREFUL / Read this :
https://kb.netgear.com/000063040/R7800-Firmware-Version-1-0-2-82
Note that starting with this firmware release (V1.0.2.82), the following features are no longer supported: ReadySHARE Vault, OpenDNS (Live Parental Controls), remote GUI access, and WPS PIN function. If you want to continue using these features, do not update the firmware.
- Smart Connect bugs (router reboots / boot loop / restarts itself)
- JayboHApprentice
Let us know how it goes
- paillassouApprentice
very very sad... reboots itself after 10 minutes... wifi drops .... internet lost... :/ :/
same bugs that the v1.0.2.8x
what i've done (to be perfect... to erase all settings) :
From v1.0.2.68 fw (works fine)
RESET v1.0.2.68 fw with push reset button 30 seconds=> router restarts with fresh v1.0.2.68 fw
launch v1.0.2.68 fw configuration wizard
SET login password
SET the router in AP mode
SET basic wifi settings
fw v1.0.2.82 update foundlaunch & start v1.0.2.82 fw upgrade
=> router restarts with v1.0.2.82 fw
wait 5 min to see white LED
RESET v1.0.2.82 fw with push reset button 30 seconds
=> router restarts with fresh v1.0.2.82 fwbasic wifi settings are :
(WPA2- AES SSID 2.4GHz / key = testwifi1 / azertyuiopqsdfghjklmwxcvbn123456)
(WPA2- AES SSID 5GHz / key = testwifi2 / azertyuiopqsdfghjklmwxcvbn123456)launch v1.0.2.82 fw configuration wizard
SET login password
SET basic wifi settingswait a moment... 10 min ... router reboots itsefl after ~10min ...
wifi drops... lost internet.... rooter restarts... :/ :/ :/
make me crazy .... :smileymad: :smileymad: :smileymad: :smileymad: :smileymad: :smileymad:
back to v1.0.2.68 fw works fine- JayboHApprentice
Does it work fine when it is set to router mode?
IT'S your post : (so i've simply copied your information)
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/New-firmware-V1-0-2-80-for-the-R7800/m-p/2078377/highlight/true#M187873 - JayboHApprentice
I also want to know what that means. We can still use a desktop browser to access the router, correct?
> > remote GUI access
> What do they mean by that?
Look for "Remote Access" and/or "Remote Management" in the User
Manual?
I know nothing, but I'd guess that the change is related to this:New Features and Enhancements:
o Supports secure HTTP protocol for the router web interface.
A casual observer might wonder why "Remote Management" (which always
used HTTPS) would need to be disabled when local access can now use
HTTPS. Incompetence would explain it, of course.
> [...] We can still use a desktop browser to access the router,
> correct?Apparently. This is Netgear consumer-grade router firmware. I'd
believe it when I saw it.
 - cappy82Aspirant
I am having the same issues as paillassou. I use my R7800 in AP mode and any firmware I've tried beyond .68 causes the device to lose wifi and/or reboot randomly.
I can't speak to using it in router mode as I do not use it as a router anymore.
- Can you imagine I have two of these and both are in AP mode. I know NETGEAR reads these forums so please be aware that we are all talking here but we will speak with our wallet when it comes to deciding the next router upgrade. I am also the resident expert for a large group of friends. Guess where their business is going - not to NETGEAR.
What company/brand would you recommend? Don't say 'any other' :smileylol:.
 Still broken in AP mode
- WahahaAspirant
Hello
I upgrade the firmware to Version 1.0.2.82 and I cannot login to the AP.
How can I login to my AP?
So far the AP work fine.
What does that mean?
You have a separate wireless access point of some sort?
You are using the R7800 in wireless access point mode?
Something else?
The R7800 has problems in AP mode with recent firmware. (I assume that you browsed through the earlier messages before hitching a ride on this conversation.)
Re: NETGEAR R7800 FIRMWARE v1.0.2.82 - NETGEAR Communities
Then there is the general issue of what you can do with a wireless access point.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
HELLO from FRANCE
=> " The R7800 has problems in AP mode with recent firmware. "
i can confirm since 10 months ... each fw update (1.0.2.7x... 1.0.2.82) big big pb in AP mode...
ARGHHHHHHHHH
i've remove that **bleep** of NETGEAR R7800 ... :smileymad:
it's a trash with the new firmware 1.0.2.82 :smileymad:
[ SOLUTION ] :
i've bought HUAWEI AX3 PRO WiFi 6+ Quad Core Enhanced Edition WS7200-30 = 50€ aliexpress... basta ...WORKS PERFECT !
bye
