ChristianWis's avatar
ChristianWis
Netgear R8000 - USB Storage and Samsung led tv
Hello everyone
I have a router with a USB R8000 1TB disk and a LED TV Samsung F5500 model with the latest update. When I want to watch movies on the disc appear sometimes shared folders and other times not appear.
But the fundamental problem is that when I get to see a movie, shows 3 seconds and then restarts ... belies any movie.
I access via WIFI. And the TV is next to the router that is that I have excellent signal.
Anyone know how to fix?
I've always had problems with the R8000 and its official firmware and Samsung AllShare.
Please I'm desperate!
Thank you very much,
Christian
  • JamesGL's avatar
    JamesGL
    Apr 17, 2016
    Hi ChristianWis,
    Are you still having issues with your router. Please provide an update.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi ChristianWis,
    1. Can you access the files or movies when using a computer?
    2. What is the file format of your drive?
    3. Can you try to use a different USB drive and see if the same problem?
    4. What is the firmware version of the router?
    • ChristianWis's avatar
      ChristianWis
      Hi
      Sorry by delay..
      Hi ChristianWis,
      Yes, I can to access using a computer
      Format is NTFS
      I cant, i have not another usb drive
      the firmware is V1.0.3.4_1.1.2
      Thanks in advance
      Christian
      • JamesGL's avatar
        JamesGL
        Hi ChristianWis,
        1. Is the Samsung TV connected via wired or wireless?
        2. If it is wireless, is it on 2.4Ghz or 5Ghz?
