marcp4726's avatar
marcp4726
NETGER AC1200 NOT CONNECTING
I have just purchased the AC1200/EX6120 range extender.
i am currently trying to set this up and bottom line is its not working!
I am in the same room as my router and i have tried the WPS method. I press the button on the extender then on the router, both buttons flash and i never receive a solid green button.
However when i look at WIFI networks i can see both of the extended networks but when i try to enter the right password the device light comes on momentarily goes off then i am told it's the wrong code. That happens on both extended wifi channels.
When i try to use the browser set up, i open the WIFI settings and it does not show me the NETGEAR option to choose and do that way.
please help.
many thanks
Marc
  • plemans's avatar
    Prior to trying to set it up using the installation assistant, did you factory reset it?
    Push and hold reset for 7-15 seconds while its powered on.
    Then try using the installation assistant
