FURRYe38's avatar
New - R9000 Firmware Version 1.0.5.42 Released
Security Fixes: 08/01/2022
  • Fixes security vulnerabilities.
For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Download Link:
https://www.netgear.com/support/product/r9000.aspx#download
Firmware Update Instructions:
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit
https://www.netgear.com/support/product/R9000.aspx#docs
Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
NOTE:  A factory reset and setup from scratch maybe needed if problems are encountered after applying FW updates:
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
NOTE: Its recommended to install a USB laptop cooler under the router for 24/4 cooling. Helps keep the router cool and helps avoid heat damage to the electronics.
This article applies to:
  • Wireless AC Router Nighthawk (1)
  • R9000
Let us know how this version of FW works for you...
  • Caution:
    Updated my R9000 to V1.0.5.42 and now WIFI is non-functional.
    Connection lights are off, Wifi button is illuminated, Wireless OFF in control, No wifi signal.
    Pressing (and holding) physical button provides no results.
    Reset multiple times and re-installed firmware
    • FURRYe38's avatar
      Did you power OFF the router for 1 minute after pressing the reset button for 10 seconds then release?
      • Jakb's avatar
        Jakb
        Tutor
        Physical Button will turn on and off blue LEDs and will disable wireless enablement in the website.
        2.4, 5 and 60GHz show as enabled in wireless settings
        After a while 60GHz signal light turns on, but 2.4 and 5 stay off and no signal found
        Factory Reset from website: no changes.
        10 second reset button with 1 min off: no changes
        Was working just fine this morning and the last while.
  • 1.0.5.42 broke ReadyCloud. Could not access my USB HDD from the internet. downgraded to 1.0.5.40 and it's working again.
    Can this be fixed?
    • FURRYe38's avatar
      Did you factory reset the router after the FW was updated and setup from scratch?
      Can this be fixed?
  • Readyshare not working. Errors = "can't find server" , No USB drive, The Readyshare access does not respond.  I've removed the USB drives and the are access able from desktop USB connection.. Power to USB drives indicated be warmth.  This post FIRMWARE v1.0.5.42 update.  The "Readyshare"  no longer appears  in Wnidows 10 Network list.
    thx,
    bob
    • FURRYe38's avatar
      thx,
      bob
      • RParadowski's avatar
        RParadowski
        Thanks for your response.  I have not performed a Factory Reset and setup from scratch. I have not done this in the past and generally do not perform factory resets on my phone, computers or watch unless there is a catastrophic failure. If downgrading the firmware does not work, I will look for another solution.  Bob.
