Benle500's avatar
Benle500
New Router Modem with Same SSID and Password with Old Router
I am replacing my old Netgear modem/router combo to a new Netgear modem/router combo model C2020/AC1200. I have more than 20 WiFi devices on the old modem/router. Do all my WiFi devices continue to work if I change the same SSID and password from the old router to the new router so I do not to reconfigure all the WiFi devices? Thank you for the help.
Ben
  • michaelkenward's avatar
    michaelkenward
    That may depend on what these wifi clients are.
    Try it and see.
    I can't find anything in the Netgear system that claims to be a C2020. CXXX usually means that it is a cable modem/router. You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Cable Modems & Routers
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
    • Benle500's avatar
      Benle500
      Sorry the wrong model. It is C6220 not C2020.
        michaelkenward
        No problem. I was just puzzled.
        The answer is the same.
        You lose nothing by trying the same SSID. Many of us do that all the time.
        You may have to reboot some of the wifi clients. But who knows?
