Styks's avatar
Styks
Night Hawk App
I have the AC1900 Night Hawk router. But when I try to access it with the iOS Night Hawk app, it says the app isn’t supported. Is there a selection in the genie that I need to make?
  • > I have the AC1900 Night Hawk router. [...]
       "AC1900" is a speed, not a model number.  Ever helpful, Netgear
    product packaging emphasizes speeds like "ACxxxx", but that's not the
    model identifier.  Look at the product label.
    > Model: R7300DST|Nighthawk DST-AC1900 DST Router
       Assuming that that's accurate:
          https://kb.netgear.com/000055505/
       I don't see "R7300DST" in that list.
  • michaelkenward's avatar
    michaelkenward
    What firmware version do you have on the device?
    A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
    There is a manual for the R7300DST somewhere at the end of this link:
    >>>>> R7300DST | Product | Support | NETGEAR <<<<<
