Swapnilb
May 30, 2017Aspirant
Nighthawk 6700v2 Not Working pls help :c
Ok, So I receieved my Nighthawk 6700v2 router today and was excited to set it up. :C then it hit the fan. This might be far fetched for most of you as it is in New Zealand, but nevertheless: my IS...
- May 31, 2017
I have contacted Netgear and they helped me get this fixed.
Thank you for helping me though :)
Swapnilb
Turns out I had to change my VID (or VLAN) setting on and onto 10. I was just messing around this morning and that seemed to work. I can't give you the model right now as I am at school, but I can assure you that the Fibre ONT does not have a built in router. Once I get home (in about 6 hours), I'll the LAN, QoS, IPv6 (although I'm pretty sure this is off).
May 30, 2017Guru - Experienced User
Maybe a configuration issue. Try with out using any VLAN configurations and test.
- SwapnilbMay 30, 2017Aspirant
So I disabled ipv6 and QoS an connected the ethernet to my computer, I still get very low data transfer.:/
Has it got to do with the NG's regions as it is still says US? As for the ONT : It is a model type 200 from the company 'Chorus'. ( I get a yellow blinking light for LAN 1 which suggests a good connection apparantly).
