Swapnilb
May 30, 2017Aspirant
Nighthawk 6700v2 Not Working pls help :c
Ok, So I receieved my Nighthawk 6700v2 router today and was excited to set it up. :C then it hit the fan. This might be far fetched for most of you as it is in New Zealand, but nevertheless: my IS...
- May 31, 2017
I have contacted Netgear and they helped me get this fixed.
Thank you for helping me though :)
May 30, 2017Guru - Experienced User
Maybe a configuration issue. Try with out using any VLAN configurations and test.
Swapnilb
So I disabled ipv6 and QoS an connected the ethernet to my computer, I still get very low data transfer.:/
Has it got to do with the NG's regions as it is still says US? As for the ONT : It is a model type 200 from the company 'Chorus'. ( I get a yellow blinking light for LAN 1 which suggests a good connection apparantly).
