Swapnilb
May 30, 2017Aspirant
Nighthawk 6700v2 Not Working pls help :c
Ok, So I receieved my Nighthawk 6700v2 router today and was excited to set it up. :C then it hit the fan. This might be far fetched for most of you as it is in New Zealand, but nevertheless: my IS...
- May 31, 2017
I have contacted Netgear and they helped me get this fixed.
Thank you for helping me though :)
May 31, 2017Guru - Experienced User
So what did they do to get it working right? Would be helpful to know so others can gain this knowledge.
Swapnilb
May 31, 2017Aspirant
Well I had to use the original Spark router as a buffer and connect the NG to it. I'm not sure what all the settings were that I had to change sorry; it was quite complicated. Pretty much if you/someone has this problem, they should just contact Netgear. That's what they are there for haha.
