mlg250's avatar
mlg250
Nighthawk AC 5300 reboots to factory settings when I plug in my Ooma Telo
My AC 5300 has been working very well with wide coverage for all of the three months I've had it.  However, I seem unable to plug my Ooma Telo into the router without having the router reboot and often having the computer reboot as well.  I have my desktop wired to the router and then the Telo would be the only other thing wired to the device.
I have an Arris 586183 modem and Time Warner Cable 200 down internet.  I get slightly over 200 on speedtest.net almost all the time, usually using a different DNS.
I haven't been able to find very much information about proper settings in Genie so that the Telo works and the router doesn't reboot.  I'm hoping I have something set wrong but I don't know what.
The AC 5300 has been working perfectly without Ooma for 3 months.
Ooma was working perfectly with my old Apple Extreme for over a year.
Therefore I am assuming there is an incompatibility - or - hopefully, incorrect settings.
Would appreciate some help if at all possible.
Thanks
  • mlg250's avatar
    mlg250
    Mar 01, 2016
    What do you mean when you say to reset the router via "gui"?  I have had to use the reset button twice to get my signal back after Time Warner was on the block doing work.  But it reset right away, found my network etc. and I was up and running.
    Thanks
  • Take backup and reset the router via gui. See without adding any additonal rules just keeping the wifi network safe with security and login changed if the router is stable. Then slowly add if any forwarding/triggering or QOS based rules along with additional settings etc. See if any new setting keeps triggering the router to reboot.
    • mlg250's avatar
      mlg250
      Thanks
  • Retired_Member's avatar
    Retired_Member
    How was it connected before. Was it between modem and router or was it after the router?
    Find your Ooma manual Read It, Study it. Depending on how it's placed in the network you'll have to change some settings. Specifically DHCP.
    • mlg250's avatar
      mlg250
      It was plugged in after the router, which (before the Nighthawk), was an Apple Extreme.  Never had any trouble.
      When you say "change settings in the network", do you mean on my computer in networking? Running Win 7 Prof 64 bit with lots of memory and disk space.
      Thanks again
