19rellimcm37's avatar
19rellimcm37
Nighthawk AC1900 R7000 Questions
I have to upgrade my home wifi ap/router due to lack of firm ware updates and I am interested in puchasing this one.
However I have few questions.
1.  Does this device support dd-wrt firmware?
2.  What is the typical cycle time that Netware will support this device with firmware?
thanks
    1.  Does this device support dd-wrt firmware? --- Yes
    The firmware is fairly mature now and there are actually not that many problems with the firmware.  The R7000 appears to be one of NetGear's most popular routers.  I would expect firmware support to be supported for several more years given the number in use and the number being sold.
  • I just downloaded the zip myself to check and the chk file is in there. I promise.
    • bpbp's avatar
      bpbp
      I see it in there, however it got corrupted someone during my download. I will have to try again! Thanks!
    • bpbp's avatar
      bpbp
      Good afternoon, how did you accomplish this? The zip file comes in the wrong format and cant seem to find out how to make that work. Thanks!
      • IrvSp's avatar
        IrvSp
        Master
        You are new to this thread. What router, what file did you get, and WHAT is the extension?
  • schumaku's avatar
    schumaku
    Might happen there are DD-WRT builds available for the R7000 platform. If you can't figure out I'm not convinced you should consider alternate firmware at all.
    Usually then security and some operational issues occur. You can build a a time line if oyu desperatley based on the information available from Search Netgear Support:R7000 Firmware Version - of corse, this deos not cmpare to the almost weekly builds some geeks are maitaning and building.
  • Yes, DD-WRT supports the R7000.
    Support and release of new firmware I don't think NG runs on a time schedule. It is both fixes severity and new exploits discovered and fixed that must be fixed that determine when a release is made as the router has been out for a few years now.
    • 19rellimcm37's avatar
      19rellimcm37
      Hmmm...I tried to search under the DD-WRT using the following terms:  Nighthawk and R7000
      Wasn't able to find it.
      I just want to make sure I can fall back to a 3rd party for firmeware if the Netgear doesn't put out firmware for it in the future.
      thanks
