Thompa3642
May 18, 2017Tutor
Nighthawk R6700v2 losing connection to CM700 Modem
Hi there, We are relatively new Comcast Xfinity custmers and decided to buy our own Modem (CM700) and Router (Nighthawk R6700v2). Every morning we find that our computers are disconnected from the ...
- Dec 27, 2017
Hi there,
Wanted to update this thread....
Since I downloaded and installed the latest firmware for the R6700 to V1.2.0.12_1.0.1, 4 days ago, my disconnection issues in the mornings has evaporated!
I know it is early days... but the update seems to have worked!
Thank you for doing this!
Made our lives much easier!
Allan Thompson
JamesGL
May 25, 2017NETGEAR Employee Retired
Hi All,
If the router has no connection, bypass the router and check if the modem has internet without rebooting it.
- JamesGLMay 29, 2017NETGEAR Employee Retired
Hi All,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- Thompa3642May 31, 2017Tutor
Hi there,
Thanks for replying - we are away from home at the moment..
Yes, bypassing the router and using just the modem, gives us access to the internet
Hoping this helps!
regards,
Allan
- JamesGLJun 04, 2017NETGEAR Employee Retired
Hi Thompa3642,
May I know what is the firmware version of the router? Make sure it is updated. (https://kb.netgear.com/000038706/R6700v2-Firmware-Version-1-1-0-34)
- Thompa3642Jun 05, 2017Tutor
Hi there,
Yes - updated to the latest firmware.
Allan
