Thompa3642
May 18, 2017Tutor
Nighthawk R6700v2 losing connection to CM700 Modem
Hi there, We are relatively new Comcast Xfinity custmers and decided to buy our own Modem (CM700) and Router (Nighthawk R6700v2). Every morning we find that our computers are disconnected from the ...
- Dec 27, 2017
Hi there,
Wanted to update this thread....
Since I downloaded and installed the latest firmware for the R6700 to V1.2.0.12_1.0.1, 4 days ago, my disconnection issues in the mornings has evaporated!
I know it is early days... but the update seems to have worked!
Thank you for doing this!
Made our lives much easier!
Allan Thompson
mbradley3
May 21, 2017Aspirant
I am having the same issues. The only difference is that we have a motorola surfboard modem. Would love some help too.
TheWorstPing
Jun 12, 2017Apprentice
which surfboard are you using?
- Thompa3642Jun 13, 2017Tutor
Sorry - don't understand - what do you mean by 'surfboard'?
- TheWorstPingJun 13, 2017Apprentice
which modem..
- Thompa3642Jun 14, 2017Tutor
There is a Netgear CM700 modem and Comcast supplied a Netgear modem for their security system.
