MOKYO22's avatar
MOKYO22
nighthawk r7000 ac1900
hi-   my router is 5 yrs old.        i see today.......my internet speed has jumped wayyyyyyyyyyy down.........
thought it was my isp,it is not.                i disconnected the router from the loop,bang, speed up to 340mb.
add router back into loop, down to 63mb.          have 2 phones,1 doorbell,1 ipad,1 smart tv and pc tower linked to router.
spped test done with doorbell on,pc on..........thats it. i have unplugged/rebooted this unit,logged in,check for updates? always tells me none?   both ethernet cables are fine.......thoughts???? time for a new one??  thxxxxx, m
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
