jerry8989's avatar
Dec 23, 2021
Nighthawk R7000 always redirects to 192.168.1.1/genie_index.htm
Hello,
My router wasn't used for a long time and I took it out to use at my parents house and I reset it and reloaded the oldest firmware (V1.0.0.96_1.0.15), so then I can upgrade to the latest firmware.
The issue I'm having now, is that I can't get back to the admin screens to upgrade the firmware or do anything else.  It keeps going to the checking internet connection genie help.  I had it hooked up to the internet at my parents and it still couldn't find the internet so now I'm working on it, but I have it connected directly to my laptop with no internet connect connected to it.  I want to access the admin screens on the router and upgrade the firmware.
Is there anything I can do to correct this issue and get it working again?
Thank you
  • Yes, That was the issue.  I figured it out.  When it asks if I want the Genie to set it up I was saying yes, but this time I chose "No" to set it up myself and it let me into the admin section.  I was able to download the latest firmware and install it and it just restarted and it looks good.
    Thank you everyone for your help.
    Jerry
  • FURRYe38's avatar
    Try a different browser?
    Factory reset the router and setup from scratch using a web browser at 192.168.1.1.
    • jerry8989's avatar
      jerry8989
      Tutor
      Thank you Furry,
      I have tried resetting the router from the back for the 30-30-30 and I tried chrome, firefox and edge and they all redirect me to the genie which checks for internet connection.  It's so weird because I was able to downgrade the firmware from the screens I'm looking for, but they won't come up again.
      • microchip8's avatar
        microchip8
        Master
        I do not have a solution for you as this is the first time I've heard of such a behavior. Just want to note that a 30-30-30 reset does not work on ARM-based routers. Only MIPS ones.
