tony-h
Apr 25, 2017Aspirant
Nighthawk R7000 as a base station
hello new here
i have nighthawk r7000 router
i would like to set it up as base and use older d-link dr-628 as extender but dont want to disable security options on nighthawk base
would appreciate any help
Ok, then leave the R7000 as the main host router running router mode.
The only way to use the DIR-628 aside from router mode is this: LAN to LAN AP mode
http://forums.dlink.com/index.php?topic=40856.0
You would place the 628 in a remote location on 2nd or 3rd floors. This will need be LAN wired from the main host router to the 628 at the remote location.
You can use the R7000 as a LAN to LAN wired Access Point. Just connect the LAN cable from the 7000 to the back of the 628. Configure the 7000 to disable DHCP, and all other features including uPnP, then configure each radio for your needs. The channels between the 7000 and 628 will need to be different. Farthest channel appart.
Is the 628 and DIR-628?
- tony-hAspirant
yes its a dir-628
your instructions are for an experienced user
a more detailed reply would really help me out
what about the security on my netgear do i have to disable it
which mode do i choose for the nighthawk, ap, bridge, or repeater
thanking you in advance i would like the connections to operate wireless
No, keep security on the 7000 at WPA2 and AES is preferred.
Yes, set AP mode on the 7000. Once you save setting and it reboots, during the reboot process, connect a LAN cable to one of the LAN ports in back of the 7000 to one of the LAN ports in back of the 628. You might need to look at the 628s connected client table to see what IP address the 7000 gets. Use this IP address to connect to the 7000 in AP mode.
Which wireless mode do you have the 628 in. I have this router too. :smileywink:
