MaxDockx's avatar
MaxDockx
NIghthawk R7000 as repeater/extender
Hello,
We moved to a new house and we got a new router/modem from our internet/digital tv/phone provider.
It is located in a small room where the electricity cabinet is.
There are 4 utp ports in the walls around the house.
I got a Nighthawk r7000 from before we moved. I want to place it in the livingroom to extend the range.
Currently the digital tv receiver is plugged in the utp port in the living room.
I thought i could plug in the r7000 there and then the digital tv receiver in the r7000.
Is this going to work?
In which mode do i have to put the r7000? Will this affect the digital tv receiver?
Thanks
  • FURRYe38's avatar
    It possible that it may work then again, may not due to the processing and lower wireless performances when using extender or repeater modes and with the processing involved. Any chance you can use the R7000 as a LAN to LAN wireless AP? Would be best if you could connect this way or if the TV has a LAN port in back, use the LAN port for best wired performances.
    Check the R7000 UI for modes of operation. There maybe AP, Repeater or Extender modes listed.
  • Hi,
    Ive seen that the tv has an utp port but im not completely sure what would be the purpose of putting the r7000 in the tv
    My installation is as followed. Utp out of the wall in the digital rv receiver. Then hdmi from receiver to the tv. If you plug the r7000 in the tv, how will it get internet?
    • FURRYe38's avatar
      You need to plug the R7000 into your main host router using the LAN to LAN port AP mode configuration. Then plug your TV into the R7000 LAN ports in back. NOT the Internet port.
  • The router is in another room than the tv. Would a direct utp cable in the r7000 and then the tv in the lan port of the r70000 work?
    • netwrks's avatar
      netwrks
      Master
      Like this, as described above: <ethernet_cable_from_router>----->Connect_to_WAN/LAN_port_onR7000<----->connect_your_TV_on_a_R7000_LAN_port> turn on tv..
  • What i did
    As manual said
    Cable out of wall into yellow internet gate
    Cable from r7000 to tv receiver
    Put r7000 is ap mode
    Change 2.4 and 5ghz names to name of router from provider
    Change both passwords to match
    Everything works perfect. Got a bit larger wifi area now
    • FURRYe38's avatar
      Glad you got it working. Enjoy. :smileywink:
