Jammers
Sep 23, 2014Tutor
Nighthawk R7000 vs R8000
I'm looking for a new ac wireless router and want to know which of these models is the best. What are the pros and cons of each router?
- Well i just pulled the trigger on the R7000. Usually i go for the latest and greatest but it sounds like the R8000 still has some bugs to work out and the R7000 more then meets my needs. :)
- AnonymousYou might try searching on this subject. I believe one or more threads are already started.
The short answer is the r8000 offers two 5g radios so if you need that option choose the r8000 if not then the r7000. - Redtulips7LuminaryR8000=R70000+Extra 5G
- FairytailVirtuoso
- LeeHProdigyOne pro for the R7000 is that there is a version of DD-WRT for it but the R8000 is not supported.
The R7000 Netgear firmware is more mature but some people still have problems with it. I do not have those problems with the newer firmware. The R7000 runs good for me.
Remember these forums are for people who have problems with their routers and most of the people without router problems don't log in here. - LeeHProdigyI spoke to soon. It looks like they will be supporting the R8000 with DD-WRT.
http://www.myopenrouter.com/download/56765/DD-WRT-for-R8000/ - JammersTutorJust what is DD-WRT and what does it do?
- AnonymousDD-WRT is 3rd party FW. It offers some options which are Not offered by NG.
- JammersTutorWell i just pulled the trigger on the R7000. Usually i go for the latest and greatest but it sounds like the R8000 still has some bugs to work out and the R7000 more then meets my needs. :)
- Redtulips7LuminaryYou made a wise decision dude :D
- dallascowboyswoAspirantWhy would you need two 5hz channels?
