MRP77
Jan 02, 2016Tutor
Nighthawk R7000 Wi-Fi is OFF (new install)
I had been holding off installing my new Nighthawk R7000 router since you never know what will go wrong... and sure enough, I've got a problem.
Basic connection to the internet went smoothly, but I can not get Wireless to enable despite reading the Netgear support pages and googling around to various forums.
- I have tried the Wi-Fi button/LED on the front panel of the device that enables and disables Wi-Fi functionality
- I have ensured that the check-buttons to enable the 2.5G and 5G radios is enabled
- I have disabled the radios then saved then re-enabled the radios
- I have reset the modem to factory defaults
- I have updated from the 1.0.4 Firmware load that the router shipped with to the latest 1.0.6 firmware
- I have ensured that enabling or disabling 1 or both of 2.5G and 5G radios turns off and on the corresponding LED's on the router front/top
Despite all this, the Netgear web interface reports Wireless as "Off" and I don't see the SSID's for my wireless network on my wireless devices (laptop, phone, tablet)
The only thing that looks weird is the channel number as shown in Advanced - Home screen (red box around it below)
Basic - Home
Basic - Wireless
Advanced - Home
Advanced - Wireless
**I removed the passwords, those fields are actually populated on the router.
Router LEDs
Any assistance resolving this issue would be much appreciated.
-Matthew
Fortunately I ended up being able to do a straight exchange where I purchased it, even though it had been longer than their normal exchange period.
I plugged the replacement in and after it booted up completely (< 90 seconds) I could connect to the default wireless network without configuring anything on the router.
So if you have this problem like I described in the original post... just exchange it. It's a hardware problem.
- netwrksMaster
I would rest to factory one more time with new firmware. If that doesn't work, I would return it..
- ceoGuide
I've had nothing but trouble with Firmware version 1.0.6.28. You may want to try downloading the older version 1.0.4.30 from this link:
http://downloadcenter.netgear.com/en/product/R7000#searchResults
and flash it to your R7000. Then perform a factory reset and configure as needed.
I'll bet that your new R7000 works much better with the 1.0.4.30 firmware.
- MRP77Tutor
Thanks for the quick replies!
I tried another factory restart with no luck.
Sadly I had already tried everything on the list in the original post while still at 1.0.4 version of Firmware, including 2 factory resets (one through the web interface and one with a paper-clip into the button on the back of the router).
If the web interface said that Wireless was enabled and I couldn't detect the signal on my wifi analyser I wouldn't hesitate to exchange due to faulty hardware. However, it seems like there is something funny in the software preventing the wireless from being enabled.
It seems clear that the design intent is that you turn on the router and wi-fi is working with the default SSID and password and that's just not the case. Very frustrating.
-Matthew
- netwrksMaster
You could try an older version of firmware, to see if that resolves the software issue. Have you tried powering off and on the wifi radios via the buttons on the router?
