75BraVo's avatar
75BraVo
Nighthawk R8000 Port forwarding invisible?
On my R8000 I know that there are Portforwardinge configured. The problem is, I can't see them.
If I create a new Port Forwarding, it's visible in the list. But I can't see the existing ones - and there are some.
If I try to create a new one for a port, which is already forwarded but not displayed in the list, I get an error, that there is already a port forwarding.
Firmware is new and reboot doesn't help.
Any ideas how to fix this?
  • Changing the language had no effect. In the end a factory reset and annoying reconfiguration fixed the problem.
  • FURRYe38's avatar
    What browser are you using?
    Does this happen in a different browser or computer?
