npinks's avatar
npinks
Tutor
Oct 19, 2017
Nighthawk R8000 to Virgin Media HUb
Tomorrow, i'm switching from BT to Virgin Media, so will be getting their superHub and i want to keep using the NightHawk X6 as my wifi, as the range is loads better and everything (inc my Arlo) connects to it without issue
Can anyone point me into clear directions to setup a Virgin hub with my nighthawk X6, so i know what to do tomorrow
  • Hi All
    Sorry for the late reply back, I managed to fully reset the X6 and upon rebooting it up, the router went through a new install and started working, with the CAT5e cable I had. Then a straight swap over to the CAT6 the following morning
    All sorted and runs perfect
  • so i have got my Virgin Hub3 installed today. Connected the Hub to the NightHawk via ethernet cable to the Yellow Socket on the back and rebooted the NH and the Virgin Hub placed in to Modem Mode, but still got no internet connection from the NH
    Tried different cables (Cat 5a & e? ) and still no joy
    Any advice, really don't want to lose the use of the NightHawk
