Blafteus's avatar
Dec 10, 2020
Nighthawk X10 AD7200 doesn't like my wifi mac address (or something)
Router Firmware Version
V1.0.5.24
I am having an issue that started shortly after I purchased this router in August.
On my Dell Inspiron 15 5579 2-in-1 ONLY, when connected to wifi, I'm connected for approximately 2 minutes and then the connection drops.  I MIGHT be able to get it back by disabling/re-enabling the wifi adapter, but after a few tries that no longer works.  If I plug in my ethernet adapter via USB, that will stay connected indefinitely.   When I take my laptop to work with me and connect to their network wirelessly I connect automatically and stay connected my entire shift(s).    So I've isolated the issue to only this laptop, wirelessly, to my Nighthawk router.
What I've done to troubleshoot:  I've updated/changed my wifi device drivers for Windows 10.  This did not improve stability.
It almost seems as if the mac address is getting a Denial of Service attack from the router itself.  Not only do I lose connection to my SSID, the wifi adapter does not detect ANY wireless connections at all, and there are several nearby.
Any suggestions?
  • plemans's avatar
    does it matter if you're connected to the 2.4ghz or 5ghz?
    Have you tried them both?
    do you have any usb-wireless adapters you can try it with?
    • That's something I have not tested/tried.  Right now I'm connected wirelessly at work with no issues.  I'll be home in a few hours and will see what knocks me off.
      The only thing is when it kicks me off, the adapter is completely shot until I disable/enable it.  I can't even view other networks that are in range.
      I do have a Cisco wireless adapter (somewhere).  I'm an electronic hoarder and not very organized so it may take me a bit to find it, unless I get lucky.
      I will report my findings here either way.
      Thanks!
      • plemans's avatar
        This would make my highly suspicious of the adapter. What wireless adapter is it?
