SWesley
Aug 13, 2022Aspirant
Nighthawk X6 AC3200 - One device places Facetime call, and all other devices lose WiFi
I have a Nighthawk X6 AC3200 - This problem started in the last month.
One device places Facetime call, and all other devices lose WiFi connections until call ends.
Has anybody else experienced this problem?
Over the last two years, this has never been an issue.
Thanks in advance for any advice!
What model router do you have? AC3200 is a combined wifi rate speed. R8000?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?How many devcies do you have online at one time?
How do you have basic and Advanced Wireless configured?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Smart Connect enabled?
Is Armor, Circle or Traffic Meter enabled?
- SWesleyAspirantR8000
Router Firmware V1.0.4.84
Arris Modem
Model TM1692A
Live in cul de sac - 3 neighbors all w/wifi
2.4GHz channel 11
5Ghz 1 channel 44
5GHz 2 channel 153 (choices 149, 153, 157, 161)
Spectrum High speed internet
Download speed typically >150 mbps
Upload typically 20 mbps
Typically have 2 TVs on
3 iPhones on
1 laptop on 24/7
Total devices:
3 smart Roku TVs
3 iPhones
1 windows laptop on wifi
1 windows PC direct network connection
Smart connect disabled
Thanks for the reply- FURRYe38Guru - Experienced User
Does same thing happen with Smart Connect enabled?
- SWesleyAspirant
FURRYe38,
Traffic Meter is enabled
Armor and Circle - couldn't find these settings
Factory reset and re-config from scratch since FW update = NO
Have not tried enabling Smart ConnectNote - ran FaceTime test from my iphone to son's iphone and didn't see wifi drop. Ran speed Test while on Facetime call no problem.
Comparing wife's iphone settings to my iphone they look the same, and updating apps on her phone, then will retest Facetime on her phone.(she uses Facetime for work calls.)Thanks again for checking in with me on this.
scott
