michaelwong's avatar
michaelwong
Nighthawk X6 R8000 Router Firmware Update Issue
There is no way for my router to update the firmware.
Tried Router Update / A router firmware upgrade is avaliable with no luck. Please help. Thanks.
  • JamesGL's avatar
    JamesGL
    Jul 16, 2017
    Hi michaelwong,
    Make sure to unzip the downloaded file. The file that should be loaded on the router has the .chk extension.
    • michaelwong's avatar
      michaelwong
      The firmware downloaded from Netgear support should be valid. However, the update is not working.
      • JamesGL's avatar
        JamesGL
        NETGEAR Employee Retired
        Hi michaelwong,
