fredbaker's avatar
fredbaker
No internet without bridge
Hello,
My previous setup of Motorla modem >> Ooma Hub >> R7000P worked fine for years, but after the Ooma Hub's recent death and rewiring the modem's output straight into the router, no internet will pass over wifi (the router still puts out a wifi signal, but it contains no data).
What do I need to do to make this work without the Hub bridging the two devices?
Thank you.
  • Has a power off for 1 minute then back ON with the ISP modem and router?
    Turn off and unplug modem.
    Turn on computers and rest of network.
  • FURRYe38's avatar
    • fredbaker's avatar
      fredbaker
      My modem is Arris SURFboard SB6141
      Since there is no wifi in my house, I can't log into my Netgear software, so I don't know the firmware version. Is there another way to log in?
      • FURRYe38's avatar
