twocharsLogs
Dec 26, 2023Aspirant
No Wifi on R9000
Hi,
My friend bricked his R9000, so I unbricked it and seeing Netgear Genie page after connecting it to my laptop over LAN Cable. But I can't find the router over Wifi, I see default SSID and password on the router control panel connected over LAN cable.
Here are all the steps I have did so far:
1. Installed very first FW that was available on Netgear site
2. Changed the password
3. Updated to latest FW
4. Updated the default SSID
5. Restarted the Router
6. Seeing following lights Power, 2.4GHz, 60GHz
Note: One of the antenna's is broken, not sure if that effects the Wifi.I haven't connected any internet cable to the router, just want to see SSID over Wifi
Let me know how to debug, fix this issue.
Does it appear when you press the reset button in back for 15 seconds then release?
- twocharsLogsAspirant
Doesn't appear even after a reset, tried it a few times.
Currently on FW 1.0.5.42.
Has any other FW like DD-WRT been loaded on this router?
Try a 30-30-30 reset on the router.
Also might try a TFTP re-load of the FW. Might try Voxels FW as well.
If these don't work, let me know, theres one last resort item to try.
