BV72715's avatar
BV72715
Tutor
Nov 27, 2020
Non existent tech support
If you are lucky enough to get through,I did after 1hr+ wait time and receiving 3 different case numbers I was told they needed to escalate my case and would email me. The email I received said that if I didn't call back within 24hrs. my case would be archived. I called back,could barely understand anyone I spoke to,and after talking for about 5 mins. was hung up on. No one bothered to call me back even though I gave a call back number in case of disconnect. Because of the non existent tech support I will no longer buy or recommend Netgear products. Save yourself hours of frustration and buy from a reputable company!
  • NETGEAR is famous for having bad support. It's because they outsource it to a third party. Their free support is also limited to 90 days after which you have to pay. Even if you pay, the support is still bad so it doesn't change a thing. They got your money already so they don't care
    • BV72715's avatar
      BV72715
      Tutor
      I totally agree! I'm going to do what I should have done to start with and buy a Synology router and return this piece of junk!
  • plemans's avatar
    Netgear phone support might not be the greatest (not the first report of this and won't be the last) Christian_R ChristineT
    But we're willing to help you out on the community support forum. We're halfway reasonable at it :)
    What router/device do you have?
    What modem/gateway is it connected to?
    What firmware is on it?
    What issue (in detail since we aren't there) are you having with it?
    • BV72715's avatar
      BV72715
      Tutor
      Thank you both for your kind offer to help but this has been such a bad experience I have bought a Synology RT2600ac and am going to return the Netgear router. I just can't see spending money with a company that doesn't seem to be interested in supporting their customers.
      • plemans's avatar
        good luck! I've heard good things about the Synology RT2600AC but I haven't had the chance to use one myself.
        I hope it works great for you!
