chopin70's avatar
chopin70
Virtuoso
Feb 01, 2018
OpenVPN certificate fix: Only 2 months left
JamesGL
Following your answer here: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/OpenVPN-update-breaks-R7000-and-probably-other-routers-VPN/td-p/1421868
We now have only 2 months left. I cannot afford having my OpenVPN broken and waiting months for Netgear to fix it. Not updating the clients is a bad answer for security reasons obviously.
1- are there wifi routers that are confirmed as of now to support the new certificate restrictions of OpenVPN client ?
2- can Netgear communicate on devices that will get the support update before April 30 ?
At least we know if we need to change device. Two months is a short term to look and order for alternative solutions if Netgear is not going to fix it
Best regards
  • Hi chopin70,
    This will be released before the April 2018 deadline.
1 Reply
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi chopin70,
