GypsyBluebell's avatar
Oct 29, 2020
Password reset for Nighthawk AC1900 WiFi Range Extender
I don't have the paperwork that came with my WiFi Range Extender (I think hubby threw it out with the box) so I don't know the password. How can I find out the password or reset the password?
  • plemans's avatar
    Nov 07, 2020
    And you still didn't specify if you're wanting the wifi password or gui password.
    Default login info:
    login: admin
    password: password
    • GypsyBluebell's avatar
      GypsyBluebell
      Thank you however I am still unable to reset the password for my WiFi Extender.
      • plemans's avatar
        Which password?
        The wifi password or the login to the gui?
        Did you push and hold reset for 7-15 seconds while it was powered on? the lights should change.
        What are the led's on it doing?
