Reenio's avatar
Reenio
Problems after updating R8000 firmware
I have a pc which only connects to the 2Ghz band but since updating the firmware it has very poor signal & drops out constantly. Other devices are connecting ok? Any known issues or fixes?
  • Hi Reenio,
    Please perform a factory reset and power cycle on the router after a successful firmware update. I also suggest making sure that the driver for the adapter of the computer is up to date. You may also use the Wi-Fi Analytics feature of the NETGEAR Genie app if you have it installed or any similar program to check for interferences and select the best channel.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Reenio,
    Dexter
    Community Team
  • Thank you for your response. I'm sorry about replying late. It was a work pc & IT updated the adapter. Works sweet now. Thanks again :-)
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Reenio,
      Good to know it is working now and you are welcome.
      Dexter
      Community Team
      • rayjos's avatar
        rayjos
        Nighthawk X6 R8000
        Firmware Version
        V1.0.2.46_1.0.97
        I am not able to establish a wireless SSH connection from my Windows machine to a Linux through the R8000 after updated the firmware. I am able to establish a wired connection. Please suggest how I may recover the functionality. I have setup port forwarding for the server.
        I see above that a factory reset my be needed but the user manual does not state how to do this.
        How do I perform a factory reset and is there anything else I should check?
