larryB1607's avatar
larryB1607
R6020 factory reset Borks internet access
I was getting really slow connection speeds so I did a factory reset.  Now I cannot get into the settings so I can update the firmware.  I have the latest version on a flash drive.  I can see that the router is connected but cannot sign in due to no internet.  I do have an Ethernet cable connected, but it says that I do not.  The usual browser router access urls like 187.162.-.- do not work.  Not sure what to do next.  Any help appreciated.
Thanks
  • Thanks for the reply, I do not own a smart phone and my chromebook cannot run the night hawk app.  I clear the browser cache regularly.
    • StephenB's avatar
      No need for the nighthawk app.  Try entering http://www.routerlogin.net  in your chromebook browser.
  • I have been to that site several times before seeing this.  I am unable to find where I am supposed to be able to get into my routers settings so I can install the latest firmware.
    • larryB1607's avatar
      larryB1607
      The router is daisy chained to a gateway.  I have been able to login.  I will see if I can find step 9 of the manual firmware install.  I will see if I can find step 9 of the manual install.
      • FURRYe38's avatar
        Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
        Couple of options,
        3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
         Static IP Address Configuration for AP Mode | NETGEAR Communities
        Try option #2 first...
