swiftdr's avatar
swiftdr
Initiate
Dec 14, 2020
R6700V2 keeps rebooting after firmware update
I recently update my R6700V2 router to firmware V1.2.0.76_1.0.1 and it keeps rebooting. It has rebooted at least 3 times today. Can I rollback the firmware update? If so, where can I download the older versions?
  • You can rollback the firmware.
    Before doing that, I'd actually reinstall the firmware over a hardwired connection, then factory reset, and do a manual reinstall (not from a backup configuration).
    to get the firmware. go to the support site and click on downloads.
    You can get the current under the downloads and the older version you'd click on "+view previous versions"
    https://www.netgear.com/support/product/R6700V2.aspx
  • plemans's avatar
    • wtsai's avatar
      wtsai
      I updated to 1.2.0.76_1.0.1 and since then, my router kept restarting every 13:35. Also having a warning message "time zone difference between router and local machine", though both router and PC have the correct NTP configured and synced.
      I downgraded to 1.2.0.74_1.0.1 per your suggestion.The router has been up more than an hour now.
      Think I don't need to purchase a new router for now.
      Thanks
      • Dave_D55's avatar
        Dave_D55
        Same here.  Router rebooted every 3 hours after I upgraded to V1.2.0.76_1.0.1.
        After I reverted the firmware to V1.2.0.74_1.0.1, it stays up.
        New router is on order (NOT a Netgear).  At least I know I can donate my R6700V2 to a good cause (after I factory reset it).
        I appreciate finding the answer here.  Thanks all.
  • Same thing is happening to me. It appears to be rebooting every 2.5 hours...
  • I rolled back the firmware to the next most recent update and the problem stopped. I guess I'll wait for the next update and try updating again.
    • jw2021's avatar
      jw2021
      I, roo, recently update my R6700V2 router to firmware V1.2.0.76_1.0.1 and since then the router has been rebooting every few hours or so. I have updated the firmware from an attached system and performed a hard reset on the router, but still the same issues others have seen. Because of the vulnerabilities in the previous version, I hate to downgrade the firmware back to what i was running previously. However, if trying to keep a reliable internet connection going, I may need to downgrade. Is there a timeframe when Netgear Support will address this issue? Thanks!
      • Brad1974's avatar
        Brad1974
        Initiate
        I downgraded mine to the previous FW and it has not rebooted since I did that...
