mediaman09's avatar
mediaman09
R7000 - Can I turn off the 5G band?
I own the R7000, but currently do not have any 5G(802.1ac) devices so I assume there is currently no advantage for this band for me at this moment. Correct?
Is there a way to runs off the 5G band on the R7000??
All I see is the option to disable SSID broadcast, but I dont see an explicitly radio on/off selection.
  • Ahh found it under Advanced Settings. Was looking under the Advanced tab. Minor item they should address - poor UI to have two different sections both called Advanced.
  • And think about if your internet is nothing faster than 150Mbps would make no benefits unless you are looking to some LAN to LAN sharing over range is less
