Falconfe73
Feb 05, 2014Aspirant
R7000 and PS4
Hi,
I have R7000 and PS4 and I have continuous disconnection of the PS4 from the PSN Network.
I tried to activate UPNP for port forwarding and I tried to put PS4 IP address in DMZ without success.
I can play for no more than 5 minutes; after this period of time I get disconnected from the PSN network.
If I use my old router (Asus RT-N66U with PS4 in DMZ or with UPNP activated) I have no problems.
Can anyone suggest me a solution?
Thanks in advance.
Thanks in advance.
- After some hours of playing it seems that the problems is solved. At the end I think it was a ps4 fault, in the sense that if you don't reset the net setup when you change the router probably ps4 "rember" something of the old router and the connection became instable.
I still have hour and date problem, yesterday I contacted netgear support but the solutions they suggested me didn't solve the problem.
- Lexist2112Luminary
Falconfe73 wrote: After some hours of playing it seems that the problems is solved. At the end I think it was a ps4 fault, in the sense that if you don't reset the net setup when you change the router probably ps4 "rember" something of the old router and the connection became instable.
Your welcome :D - AlexAmparanAspirantI have to r8500 how do I put it to ps4 5g
- JamesGLNETGEAR Employee Retired
Hi AlexAmparan,
You mean how to connect the PS4 to 5Ghz connection? If yes and if it supports 5Ghz, you may the network connection and look for the 5Ghz network.
- PS4 doesn't support 5 GHz.
- Tmoney007AspirantYou need sip alg enabled and you need to .Mac clone new router with old router mac. Once modem sets up com with new u can put défaut mac on new router
