Bart83
Mar 26, 2019Aspirant
r7000 bricked after update
Hello,
While updating the firmware to the latest version. The router stopped responding and now I am unable to access it or reload firmware. The power button is white and flashing. What can i do? update en then is broken thats not correct.
Thank you, He is working:D
- jbae843123Aspirant
I'm sorry to hear that...
I updated to version 64 a couple of weeks ago, and I noticed many issues, but it did not brick my router.
When I just checked the release note of version 64, it had "Last modified" of 3/26/2019, instead of 1/??/2019.
Maybe they re-released the firmware under the same version number, and it was a bad one?
To fix the issue, try factory reset? or check this link out.
I hope everything works out
- Bart83Aspirant
A more recent explanation of the process is here:
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
- buster_petalumaAspirant
Got an email recommending update. I used the Netgear App to update. Click, Download,Install. Easy. But, the power light blinked constantly white. waited 35 minutes for the hair-ball to clear. Didn't. All devices are dark. No internet, ROUTER BRICKED. Mac OSX environment.
Tried every idea I had, tried ideas online and here (had to use my phone).
Had to go buy a new router (imperiative that I get back in business now). Not happy having to replace my 2 yr old R7000. Hopefully the new AC3000P lasts longer.
> [...] Tried every idea I had, tried ideas online and here (had to use
> my phone). [...]Think for a moment about how little useful unformation that
non-description conveys to the non-psychics in your audience.> [...] But, the power light blinked constantly white. [...]
You may be a candidate for the TFTP recovery scheme. See, for
example:https://community.netgear.com/t5/x/x/m-p/1622096
> [...] waited 35 minutes [...]
I wouldn't expect time to cure a flashing power indicator.
The Mac-specific details are covered in that cited thread (and links
therefrom).> Had to go buy a new router [...]
Rehabilitating the old one as a spare might be useful someday, then.
Rehabilitating the dead R7000 is not possible. It will not communicate with my devices/computers.
It does not even send out a network signal - it can not be "seen". It does not show up in Networks list. It is just dead/bricked.
Hope no one else experiences this.
