penpod's avatar
penpod
R7000 Not allowing full speed
Need some help getting router to allow full ISP speed. Here’s where I’m at:
Upgraded ISP speed to 300Mbps, but have always had consistent 96-98Mbps speed, even after upgrade. Had service provider here to check all signals and rework some cable. Was told to upgrade modem to DOCSIS 3.1 (previously a DOCSIS 3.0). So, went and bought the Arris SB8200 Surfboard. Now I’m at consistent 85Mbps. So, figured the router is capping the speed. When the service provider was here, I saw he was getting 250+ straight from the modem. I also plugged into the modem only and confirmed upper 200Mbps down after activation of the new Arris modem. I read a lot of articles here to troubleshoot, but no success. Verified QOs was disabled, verified Traffic Meter is disabled. Was running 1.0.9.88 firmware, so I dropped back to the 1.0.9.42 firmware, but when that didn’t help, moved back to 1.0.9.88. Checked statistics, they are:
WAN: 1000M/Full
LAN1: 100M/Full
LAN2: 100M/Full
2.4G WLAN: 600M
5G WLAN: 1300M
At a loss now on next steps. I can’t seem to figure out why the router is capping my speed. I changed out all the Ethernet cables to brand new CAT6. Only hardwired items into the router are the modem and the Apple TV. Any thoughts or suggestions on what else could be the issue? Thanks in advance for the help!!
  • > Model: R7000|AC1900 Smart WIFI Router
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.  Look for the
    LED descriptions and "Troubleshoot".  Then look at the LAN Ethernet
    port-status LEDs on the router?
    > [...] I can't seem to figure out why the router is capping my speed.
       What makes you think that the router is your bottleneck?
    > WAN: 1000M/Full
       That suggests that the link between the modem and the router is
    running at gigabit/s speed.
    > [...] Apple TV. [...]
       I know nothing about your (unspecified) "Apple TV", but many TVs have
    slower-than-gigabit/s Ethernet ports; they simply don't need higher
    speed to do their job.  I'd expect an amber port-status LED on that
    connection.
    > 2.4G WLAN: 600M
    > 5G WLAN: 1300M
       Wireless speeds depend on many things, including the capabilities of
    the client device.  Such theoretical maximum speeds are seldom
    realistic.
    > [...] 1.0.9.88 firmware, [...]
          https://community.netgear.com/t5/x/x/m-p/2069376#M186506
    • penpod's avatar
      penpod
      >[…] Read. Look for the
      port-status LEDs on the router? […]
      Apologies for leaving out that detail. I did read the manuals and troubleshooting as much as I could before posting, which is why I’m now posting because I’m stuck
      >[…] What makes you think that the router is your bottleneck? […]
      Because I mentioned modem speeds are fine, but output after router seems to be the issue. Unless it’s cables, which I also mentioned I swapped out for new ones.
      >[…] That suggests that the link between the modem and the router is running at gigabit/s speed […]
      Exactly, so this is also the reason for thinking the issue above.
      >[…] I know nothing about your (unspecified) "Apple TV" […]
      Agree and nothing to worry about here. I just posted that detail for context as to what was plugged into the router, since details are sometimes helpful.
      >[…] https://community.netgear.com/t5/x/x/m-p/2069376#M186506 […]
      Not sure why the link. Are you advising to try the latest firmware?
      • antinode's avatar
        antinode
        Guru
        > Apologies for leaving out that detail. [...]
           This reveals what, exactly, about what the LEDs are doing?
        > [...] but output after router seems to be the issue. Unless it's
           "cables" to _what_?  The best cable on the planet won't make a slow
        device faster.
        > Agree and nothing to worry about here. [...]
           Then about what, exactly, are you complaining?  "speed" to _what_?
        > [...] Are you advising to try the latest firmware?
           You seem to be trying different versions, none of which is the
        latest.  Any reason?
