jimmyk8
Mar 18, 2017Aspirant
R7000 Speed issues
Good Afternoon, I have noticed that over ther past month my WiFi has been dropping and the speed is not what it should be. I have Xfinity 75/10 speed. When I checekied today I was getting...
- Mar 19, 2017
Thank You very much all for the support.
This mornign I went through more firmware changes to no avial. I went back to verify that to the modem was still good, it was not.
I called xfinity, they had to make a change on their side, noting that I needed to get up to date firmware from motorola on my modem.
All is well.
jimmyk8
I forgot to note,
I did a full reset after the firmware upgrade did not solve the problem.
aalexandrebeta
Mar 18, 2017Master
You can olso go back to the previous FW if it does not solve this issue!
