slapi2000's avatar
slapi2000
R7000: UPNP Renderer not visible when connected via WiFi
Hi all,
I use the R7000 as a router and have the problem that my UPNP renderer (Denon DNP-F109) is not visible if connected via WiFi (via Ethernet, everything works fine).
Can anybody give me a hint what to do here?
I have switched on DHCP and UPNP in the configuration. All UPNP devices (renderer/server/controller) are in the same local 192.168.* network.
Many thanks
Stefan
  • JamesGL's avatar
    JamesGL
    Jan 11, 2016
    Hi Stefan,
    Please perform a reset on the device and check again if still the same problem.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Slapi2000,
    What is the IP address of your renderer?
    Can you ping the IP address?
    Do you have other devices working with wireless?
    What is the firmware version of the router?
    • slapi2000's avatar
      slapi2000
      Hi,
      IP address: 192.168.1.2 (static assignment)
      Ping: yes
      Other devices: yes, few mobile phones/tablets (none of which with any UPNP role).
      Firmware: V1.0.6.28_1.1.83 (the bug is there since a number of releases - I have been hoping since a while this gets fixed at some point)
      Best regards,
      Stefan
      • JamesGL's avatar
        JamesGL
        Hi Stefan,
