Iris4Thug
Dec 07, 2015Aspirant
R7000 v1.0.5.48 breaks 5G in Operation Mode:Access Point
Updated firmware to latest version (R7000-V1.0.5.48_1.1.79) and the 5Ghz radio was no longer working for main and guest networks. The 2.4 GHz radios seemed to still be working properly. I did not s...
- Dec 08, 2015
After the factory reset, make sure to re-enter the setup parameters manually, do NOT restore from backup, that appears to be incompatible as well.
Retired_Member
Dec 07, 2015I ran mine in AP Mode without that problem but due to a $_itload of other problems I reverted back to 4.30 after shelving the r7000 for a week.
- JamesGLDec 07, 2015NETGEAR Employee Retired
Hi Iris4Thug,
Did you try resetting the router to factory default after the firmware update to v1.0.5.48_1.1.79?
- Retired_MemberDec 07, 2015
I did.
- Iris4ThugDec 07, 2015Aspirant
I did not reset back to defaults. However, that would have been my next step if rolling back to previous firmware version didn't work.
If you want to use again the latest firmware then try resetting it after that update and see if that works.
