Iris4Thug
Dec 07, 2015Aspirant
R7000 v1.0.5.48 breaks 5G in Operation Mode:Access Point
Updated firmware to latest version (R7000-V1.0.5.48_1.1.79) and the 5Ghz radio was no longer working for main and guest networks. The 2.4 GHz radios seemed to still be working properly. I did not s...
- Dec 08, 2015
After the factory reset, make sure to re-enter the setup parameters manually, do NOT restore from backup, that appears to be incompatible as well.
Retired_Member
Dec 07, 2015I ran mine in AP Mode without that problem but due to a $_itload of other problems I reverted back to 4.30 after shelving the r7000 for a week.
JamesGL
Dec 07, 2015NETGEAR Employee Retired
Hi Iris4Thug,
Did you try resetting the router to factory default after the firmware update to v1.0.5.48_1.1.79?
- Retired_MemberDec 07, 2015
I did.
- Iris4ThugDec 07, 2015Aspirant
I did not reset back to defaults. However, that would have been my next step if rolling back to previous firmware version didn't work.
- JamesGLDec 07, 2015NETGEAR Employee Retired
If you want to use again the latest firmware then try resetting it after that update and see if that works.
- rpoffenDec 08, 2015Virtuoso
