Iris4Thug
Dec 07, 2015Aspirant
R7000 v1.0.5.48 breaks 5G in Operation Mode:Access Point
Updated firmware to latest version (R7000-V1.0.5.48_1.1.79) and the 5Ghz radio was no longer working for main and guest networks. The 2.4 GHz radios seemed to still be working properly. I did not s...
- Dec 08, 2015
After the factory reset, make sure to re-enter the setup parameters manually, do NOT restore from backup, that appears to be incompatible as well.
JamesGL
Dec 07, 2015NETGEAR Employee Retired
Hi Iris4Thug,
Did you try resetting the router to factory default after the firmware update to v1.0.5.48_1.1.79?
Retired_Member
Dec 07, 2015I did.
