Iris4Thug
Dec 07, 2015Aspirant
R7000 v1.0.5.48 breaks 5G in Operation Mode:Access Point
Updated firmware to latest version (R7000-V1.0.5.48_1.1.79) and the 5Ghz radio was no longer working for main and guest networks. The 2.4 GHz radios seemed to still be working properly. I did not s...
- Dec 08, 2015
After the factory reset, make sure to re-enter the setup parameters manually, do NOT restore from backup, that appears to be incompatible as well.
JamesGL
Dec 07, 2015NETGEAR Employee Retired
Hi Iris4Thug,
Did you try resetting the router to factory default after the firmware update to v1.0.5.48_1.1.79?
Iris4Thug
I did not reset back to defaults. However, that would have been my next step if rolling back to previous firmware version didn't work.
- JamesGLDec 07, 2015NETGEAR Employee Retired
If you want to use again the latest firmware then try resetting it after that update and see if that works.
- rpoffenDec 08, 2015Virtuoso
- Iris4ThugDec 08, 2015Aspirant
Thanks I did try this and it seemed to work. It hasn't baked in for days to where I am comfortable with this, but so far it seems to work and the 5GHz radio broadcast is staying on. Also, thanks for warning me about the backup as I would have normally tried this as I always backup up before a firmware upgrade and then again after and save all versions just in case. Since I am in AP mode, I don't have this super customized like my router so putting all the setting back was manageable but nevertheless a pain.
So is anyone saying this is a confirmed bug and if this will be addressed in next firmware?
