donEddie7
Aug 17, 2017Aspirant
R7000 Wireless Issues w/ Microsoft Surface Pro 4, Works Fine w/ other Devices
Hello,
I've recently begun to have issues connecting my Surface Pro 4 tablet to my home Wifi even though other devices have no trouble connecting via Wifi or Hardwired. My firmware version on my router is V1.0.9.6_1.2.19. Wireless Settings below.
The problem: My Surface is able to connect to either the 5Ghz or 2.4Ghz Wifi bands. When opening a browser (any browser), pages begin to load then never complete. My Surface never shows that it is disconnected, but sometimes will show limited connectivity. Sometimes, the page finishes loading, other times it will half load or not load at all. Sometimes, it only appears that the internet is moving VERY slowly whereas others, it's clear the connection is dead. The behavior is the same with both bands. We have other devices at home that are hardwired or connected to either wireless band and have no issues at all. Devices connected to wireless are Apple iPhones and iPad, another Windows laptop, a Wireless printer, AV Receiver, TV. All of those devices are able to connect without issue. Nothing has changed with our setup at home. We use a Netgear Modem, and connection is great when connected directly to the modem, so I don't suspect issues with that. I've also got several hardwired devices, some of which are always on and never have connection loss.
Things I've tried to fix:
- Connecting directly to modem, any device works fine.
- Hardwiring from router to Surface Pro 4 using an ethernet adapter, works just fine.
- Brought an entirely different Surface Pro 4 home from work to test, same issues. Both are wunning Windows 10 Pro x64 Creator's Update. Both have been updated with all Windows Updates.
- "Forgot" all networks, connected "fresh" to both bands, no change.
- Uninstalled Wireless Adapter from Surface and restarted, no change.
- Uninstalled Wireless Adapter and Forgot Drivers from Surface. Installed Drivers from Microsoft Provided Drivers. No Change.
- Attempted to ping google.com or cnn.com while connected to the wireless, the pings seem to go through just fine. Occasionally, I will encounter one with a high response time, but others are consistent.
- Replaced the Router entirely with another R7000, same issues.
Much of my testing leads me to believe that there is some incompatibility with the Wireless Drivers the Surface is using and the Netgear R7000 Router, but I haven't found anything definitive online. I've also had trouble finding threads with my specific problem. I wasn't really sure where to look so I figured I'd post in case anyone had any ideas. I work in IT and have been frustrated by these issues. Hopefully someone can help. Thanks!
Notes:
- Smart Connect is Disabled
- Enable 20/40 MHz Coexistence is checked on.
- Channel is Auto for 2.4GHz
- Mode is up to 600 Mbps on 2.4GHz
- Channel is 153 for 5GHz
- Mode is up to 1300 Mbps for 5GHz
- Transmist Power Control is 100% for both bands.
- Security is WPA2-PSK [AES] for both bands.
Hi Keigotw,
A new firmware update is available. Please update the firmware to 1.0.9.32.
https://kb.netgear.com/000059134/R7000-Firmware-Version-1-0-9-32
Blanca
Community Team
- JamesGLNETGEAR Employee Retired
Hi donEddie7,
Will the Surface Pro works on different wireless network?
- donEddie7Aspirant
Yes, Both Surface devices tested appear to work fine on Wifi in my office at work. I also tried to work them off a hotspot and they worked then as well. That's why I originally thought to replace the Router. But since both Surfaces had issues with both routers, it points back to some sort of incompatibility between the two devices. My guesses is that it has much more to do with the drivers/settings for the Network Adapter on the Surface than it does with the Router, but I've found many threads blaming both sides. That's why I figured I'd see if anyone on the Netgear forums had any ideas first.
I wanted to note that I did not Backup my first Router and then restore the settings to the 2nd Router. Just in case we thought maybe it may be a corrupt backup or something. Settings were entered manually.
- TECHeSmurfAspirant
I have the same issue on my Pro3 and Pro 2017.
- KeigotwTutor
I am having the same problem, even with the lastest firmware on R7000. Only Surface Pro 4 have issue with R7000, other computer, Ipad, iphone, Samung S8 all works
Even trying guest access on R7000, did not work well.
Surface pro 4 works fine with Netgear R8000.
I have now replaced R7000 with Linksys WRT1900AC and Surface Pro 4 is working fine.
Hope Netgear can figure out the problem with the R7000
- donEddie7Aspirant
Yes, they've ruined it with their firmware updates. My Surface is still working only on the Guest Network, and now I'm having an issue where my phone is only getting ~ 25Mbps from the Wifi, while other devices are getting 200Mbps. It's as if they don't even test the firmware before sending it out.
- Rjp2003AspirantDoes anyone know if using router 7900 will resolve the internet connectivity issues with surface pro 4? Thanks
