required_alias
Feb 28, 2023Guide
R7000
Should be easy. I was sent a new Internet modem by my ISP. Since then, I can't log in to my 50 network. when I type in 192.168.1.x in my browser, I get the ISP home page. How do I access my router?
Can't give version, etc because I can't access my router.
Is the R7000 in router or AP mode?
Set up R7000 as router.
Optimum communications - Ubee modem. Model # UBC 1322
Seems like that modem has a router built in on it already:
This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.What happens when you disconnect the NG router from the ISP modem temporarily? Can you log in to the NG router then?
- khustabakAspirant
Everytime I have a power outage or some form of issue where the router loses power, the internet speed throttles down from lets say 235 download to 66 download. In order to fix this, I need to go on my laptop, go into the QoS setting in my routerlogin.net and do a manual speed test. Somehow by doing this, the speed "unlocks" and is back to normal.
I have the Nighthawk R7000 with Netgear CM400 modem, with Xfinity.
Any help appreciated!
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. The firmware version installed, for example.
