FlashFlood's avatar
FlashFlood
R7800 ReadyShare rejects connections to drives secured by admin password. Must update admin password
R7800 ReadyShare rejects connections from all devices to USB  drives (2) secured by admin password. Must update admin password to itself to restore connections.
This occurs periodically. I have not been able to correlate this to any particular event.
Firmware version V1.0.3.92
  • michaelkenward's avatar
    michaelkenward
    1.0.2.92?
    Where do you see this? Windows?
    The R7800 hasn't caused me any problems on that front. But mine is now in AP mode, simply to give me ReadyShare.
    Just another user with time on their hands.
    • FlashFlood's avatar
      FlashFlood
      Connections to the drives fail on MacOS, IOS, Android and Windows platforms. I connect to the router, update the admin password to the same value and I am subsequently able to connect to the drives from all devices.
      I do not have to update any configurations other than the admin password to restore connectivity. I recall reading some time ago that it was necessary to update the admin password after adding a new drive and securing it with the admin password. It seems like ReadyShare configuration reverts to this initial state periodically. When it first happened, I updated with a new password and changed the connection credentials on all my devices until I realized I can just update the password to itself to resolve the issue. Still very annoying when it happens.
        michaelkenward
        Do you really need to password protect the USB drives? I don't.
