eggt4rt's avatar
eggt4rt
R7900P - Unable to access admin page after firmware update
Hi all!
Happened a while ago.  Last I recall, I updated to the latest firmware and can no longer access the admin page via the app or routerlogin.net. I get a connection timeout from the webpage and WiFi Not Detected from the app (even though my phone is on WiFi from the router).
My router still works as in I can connect to the internet from ethernet cable and WiFi. Just can't access the admin page anymore to configure anything.
Appreciate any suggestions.
Thanks!
    • eggt4rt's avatar
      eggt4rt
      Thanks for the reply!
      Since I am no longer able to verify, I assume it is the latest available one: 1.4.4.94
      I have tried different browsers on multiple devices and in incognito mode trying both routerlogin and 192.168.1.1
      From my understanding, resetting the router does not make any changes to the firmware.  I don't know if I want to take the chance to reset it and not be able to access the admin page to set everything back up since it is currently working.
      • FURRYe38's avatar
        Can try inputting a password 3 times then you should get a recovery PW screen using a browser.
        If this fails, you'll need to factory reset the router and setup from scratch.
  • plemans's avatar
    What modem/gateway is it connected to?
    I've ran into that issue when in a double nat.
    Otherwise, a factory reset is a good option to get bac in
    • eggt4rt's avatar
      eggt4rt
      It is currently connected to a BGW320-500 in bridge mode.  I don't have any issues connecting to anything online so not sure if it is double NAT.  I could try to disconnect it from the modem/router to see if that changes anything.
      • FURRYe38's avatar
        Try disconnecting it from the ISP modem. Use the IP address for the gateway seen by your ethernet connected PC to the R7900 in a web browser.
        If this fails, you'll need to factory reset the router and setup from scratch. I would do this disconnected from the ISP modem first, then after it's setup, reconnected it to the ISP modem.
  • StephenB's avatar
    Did the LAN subnet change?  Have you tried browsing directly to the router ip?
    • eggt4rt's avatar
      eggt4rt
      Hi Stephen!  If the LAN subnet did change, I did not do it.  I have tried 192.168.1.1 (if that is the correct IP). After the update, the app used to see it and tries to connect.  With the latest app ver (2.54.1), it doesn't even see it at all.
      • StephenB's avatar
        Check the IP address on the client device you are using.  If that isn't 192.168.1.x, then the subnet has changed.
